Help: speaker settings (BOSE AM10 plus VC-10)
C
coolposter
Hi there,
I'm having a Bose Acoustimass 10 plus a Bose VC-10 center unit.
I replaced the center unit with VC-10. And hooked up that satellite speaker to Surround Back.
In AM 10 manual, it says set all these speakers (5 satellite) to LARGE.
VC-10 says set it to SMALL.
What is the correct setting?
Hi coolposter, You have a separate sub in the BOSE Module that the speakers output from yes? if you do then set all the speakers to small and let the sub do all the work with bass. It wont go all that deep wont your module but this is how you should set them up.
Hope this helps,
Regards,John.
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
