Help! Speaker positioning advice - Room layout provided.
Discussion in 'Home Cinema Buying & Building' started by Munzz, Aug 10, 2013.
  1. Munzz
    Munzz
    Dec 19, 2010
    126
    +18
    Hi All,
    I purchased today a Yamaha RXV373 and a Tannoy SFX 5.1 for my bedroom, mainly to be used with my iPod and the occassional movie on my 42" LG LCD display.
    All is going well so far and I will be mounting my FL, FR and centre speakers tomorrow (see attached) but I am struggling to decided where to put the final 2 satellites. I'm either thinking the wall directly behind me (more like 1 on the shelf and 1 mounted on the wall) or x2 above the window?
    I've attached a plan of my room, for reference the TV is mounted around 70cm above my bed on the wall.
    Any help/advice would be greatly appreciated :smashin:
  2. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    720
    Thame
    +69
    The suggested placement would be one each side of you and facing towards you, roughly at head height or a bit above. So, one next to the window and one in front of the shelves?
