Help - Speaker impedance query
Discussion in 'Home Cinema Speakers' started by megson, Aug 8, 2004.
  1. megson
    megson
    May 13, 2003
    323
    28
    Tipton
    +77
    I am currently setting up my all brand new K series speakers. K17 fronts, K4 rears and K10 subwoofer.
    I have the Denon A1 "uber" amp ready to power my speakers in my new AV room when the builders have finished it but I am wondering if, in the short term, my Yamaha 620 amp could be used to run the M&K's in. The Yammy currently runs my Kef egg speakers in my lounge but it is not practical at the moment to install and set up the Denon.
    The impedance of my K series speakers are all 4 ohm but my Yamaha instruction manual says that the main speakers can be 4 ohm but the centre and rears should be 6 ohm or higher.
    Does this rule out using the speakers with the Yammy? I know that the amp has protection circuitry built into it but I don't fully understand the technical side of things.
    Any help or advice would be gratefully received.
    Regards
    Megson
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Your Yamaha will run them but keep the volume levels fairly low otherwise you risk overloading the amp.
