"Help" sony projection
Discussion in 'General TV Discussions Forum' started by darren7, Aug 12, 2002.
  1. darren7
    darren7
    have a Sony KPS53s4U.. it has started showing blue edges on the rright side of the screen, I pulled up the menu and looked at the convergane, the blue was out to the right and more at the botton of the cross, I then went to adjust this and it would not move, the red will go up and down and left and right, the blue will go up and down, but it wont move left or right from the remote.
    the tv is 4 years old, what could make this happern, only on the blue, I think if someone reads this thay may be able to pinpoint this problem.
    or how much, good service place Essex?
    Please reply.
    Dave :-?
  2. saucytoe
    saucytoe
    I recently purchased a Toshiba 56" RP and had similar problems with the convergence I just contacted the dealer to replace it for me as your Tv is some years old I would recommend going to a local sony dealer and having a technician look at it. I think possibly screen burn may have caused this problem. Good luck anyway:)
