Help ! Small Circle of Green Light at boundary of Sanyo Z1 projected imag !!??
Discussion in 'Projectors, Screens & Video Processors' started by AVJ, Oct 2, 2004.
  1. AVJ
    AVJ
    Dear all Sanyo Z1 owners !
    I recently discovered a small circle of green light (of low intensity) showing at the boundary of the Sanyo Z1 projected image !!??
    Do anyone of you know what's happened to my Z1 ? and how to fix it ?
    Looking for your greatest help & many thanks !!!
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
    Not a Sanyo owner but the artefact you describe sounds like a dust particle lodged on one of the LCDs. You can prove this by defocusing the PJ in one direction or the other - if the circle begins to take a distinct form, you have a dust blob.
    You'll need a clean air blower - buy it as an aerosol from somewhere like Maplins. And instructions (which, unfortunately I can't provide) as to how to partly dismantle your PJ to get access to the LCDs and Prism assembly to blow it clean.
