Help: Sky+ Remote Codes - website not working
Discussion in 'Sky Digital TV Forum' started by cR4cKF0x 5TevE, Oct 27, 2005.
  1. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,695
    St Merryn
    +582
    Help, I have been looking for the Sky+ remote codes for my new Hitachi 42PD7200, and when I try to use the following link it tells me that the website is unavailable or may have been moved
    http://www.hummer.co.uk/remote-setup.htm
    Anyone know where this site has moved to?
    :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    24,151
    Lanarkshire
    +2,651
    No sorry but have you tried looking for a code within the "Interactive", "Sky Customer Service" menu?
  3. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,695
    St Merryn
    +582
    Why is the most obvious place to look always the one you never think of?
    Hope the Hummer site does go live again, I have found it invaluable in the past.
  4. Cynthia 7
    Cynthia 7
    Hi gg,
    If you don't have any luck with the Sky codes try this site. Look at the newest tables at the bottom of the page. Lots of members have had difficulty in finding the Sky codes for the latest television. Check the version number in your Sky remote (in the battery compartment). The latest version is 6; if your version is an old one it's likely it hasn't been programmed with the latest televisions. Good luck!
    http://www.satcure.co.uk/tech/digicode.htm
