help: sky+ popping sound through speakers
Discussion in 'Sky Digital TV Forum' started by darren7, Dec 30, 2002.
  1. darren7
    darren7
    I have just setup my sky+.
    every now and then there is a crackling sound thhrough the speakers, it is going through the usual route re:decent scart and RGB into ext1 RGB, on a Philips 32".
    this tv has never had any sound problems before and I have tried all the sound modes on the TV.
    is the box faulty? any views.
    D
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Try these.....
    Turn down the digibox audio output volume.
    Make sure the scart cable is making good contact.
    Replace the scart cable with another.
    Try connecting using a different method, RF or composite.
    Take the audio from the digibox direct to an amp using the optical or twin phonos.
  3. purple52
    purple52
    Jan 10, 2002
    41
    11
    London
    Did you manage to isolate the problem yet?
    My TV (a Loewe Aconda) is doing a similar thing.
    I didn't get around to unplugging things to isolate the problem, but the noise continued even when tuned to terrestrial channels with the Sky+ on stand-by. After a while, the TV blew a fuse and had to be repaired. I therefore assumed it was a fault on the TV.
    Since being repaired, however, the problem has returned, but not as bad as it was before.
  4. dejongj
    dejongj
    Actually I am getting this as well. It started a few days back. I have no connection to a TV just to my amplifier and video to the projector.
    I thought it was down to some broadcast problems as it did sound like the digital artifacts you can get.
    Cheers,
    Jean-paul
  5. eddiewww
    eddiewww
    Nov 14, 2002
    449
    46
    Blackheath, SE London
    +136
    seems a common problem...
    how is the audio connected..fibre or analogue ?
    i have had a crackling noise like electric discharge...but since i have changed from fibre to analogue it seems to have been reduced.
    eddie.........
  6. dejongj
    dejongj
    I am connected analogue only as I do like the digital on music channels and no normal broadcasts are in 5.1 anyway....
    Cheers,
    JP
  7. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    I've just started getting this also - i'm using optical only.
    just a guess but has anyone else recently manually upoaded the new software for instant rewind ? could this be the link ?
  8. MatC
    MatC
    Jan 16, 2003
    77
    9
    I used to get this problem with my Philips 32" TV. I called the shop I bought it from and they sent an engineer who soldered some resistors (might have been caps)into the feed on the Scart inputs. This seemed to clear the fault to a degree, with just the occasional popping noise. I have since gone into the services menu on my sky box and turned down the volume, and this has cured the problem totally.
    Hope this helps.
    Mat
  9. Eakley
    Eakley
    Thanks for this. I've got the same problem so will see if it cures mine.
  10. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    I have this problem too - I'm connected via optical. I've tried turning down the volume, but it's not made any difference. ANyone got any other suggestions?
  11. purple52
    purple52
    Jan 10, 2002
    41
    11
    London
    I've still not worked out exactly what's causing mine; I wonder if we're all actaully suffering from the same problem or not?
    Latest development; I finally plugged my Sky+ into my amp (phono lead, not optical) and found that with the TV muted, I still get the crackling noise, but through the TV speakers and not through the amp...
    I'm going to try removing the scart completely next, and seeing what happens just using an aerial lead.
    David
  12. Karma
    Karma
    May 20, 2002
    375
    Birmingham
    +11
    Interesting. I have suffered this for a long while. I always put it down to over load at theSky end. ie it is what happens when they over load the audio by recording it too loud. Digital sound doesn't run gently into distortion like analogue.
    The reason I got Sky+ was because of the digital 5.1 output but won't now connect it to my home cinema system because of this problem. I don't want to squarewave my speakers. No Sir!!
    I'd be interested in seeing the solutions.
    BTW can anyone remind me how to get into the engineers menu on the digibox.
  13. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Any more info. on this? It's getting really annoying. It only seems to happen on playback - I get a "pop" about once every minute.
  14. purple52
    purple52
    Jan 10, 2002
    41
    11
    London
    CJ,
    I think my problem might actually be the TV rather than the Sky+ box. I tried unplugging Sky+ completely, and just leaving my aerial cable in. I still got the occassional pop, but it was less than 5% as bad as it had been.
    On Sky, it seems to happen more when watching certain programs, so I suspect that it is related to either video or audio levels/peaks. Perhaps there is an issue with the levels output by the Sky+ box, and some TVs are more effected by it than others?
    David
  15. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Thanks David,
    mine's connected to a TagAV32 (via optical) and not to a TV. I have a number of inputs connected including two other Sky boxes (not Sky+) via two TiVos, and I don't hear the popping on any other source optical or not. I guess I could try the Sky+ box via phonos.
    I'm fairly certain I only hear the popping on Sky+ playback.
