Help - Sizzling and Spitting !
eimer3107
My speakers (B&W M1s) have recently begun to sizzle and pop. Things mostly seem ok when I first switch the system on, but breakfast frying noises soon break out.
I've tried disconnecting all the wires and cables one at a time in an attempt to isolate the problem, and I've tidied up my cables to try to keep power cables as far as possible from everything else, but no joy.
Is it likely to be a fundamental problem with my amp - an Arcam AVR280 ?
Is there anything else I should try ?:confused:
Mark.Yudkin
It does indeed sound as if the AVR280 could benefit from a service by suitably qualified personnel.
o0paradigm0o
At least get some bacon and eggs going. If it's both speakers, it's definitely your amp. Glad I bought the 350... no sizzling and popping noises...yet!
Slackadder
Established Member
Evening
Best call Arcam. I had a really horrible static noise (intermittent) that would occasionally appear and then the amp would shut down.
Went back to Arcam - fixed!! Problem was blown cap and the DSP chip (a know issue) needed fixing (reworking).
Good luck!
Anthony
🎬 The Top 20 Most Anticipated Movies of 2024
Back
