Help - simple question needing an answer - beamax screen
Discussion in 'Projectors, Screens & Video Processors' started by scouse258, Jul 18, 2005.
  1. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    :lease:
    hello
    i took the plunge and bought my first projector screen
    its a beamax velvet (special offer on at hifibitz) fixed screen
    i have had problems fixing it up to be honest - the instructions wernt the best
    i have done the frame and im left to put the fabric on - HERES THE PROBLEM.....
    THE FABRIC IS "Matt White 1.2 Gain".
    IT HAS TWO SIDES - A SHINEY ONE AND A MATT ONE WITH A SLIGHT TEXTURE
    AM I RIGHT IN THINKING I FIX IT SO THE PROJECTED IMAGE IS ONTO THE MATT SIDE
    A STUPID QUESTION BUT I WOULD HATE TO MOUNT IT TO FIND I HAVE DONE IT WRONG!
    THANK YOU THANK YOU THANK YOU
  2. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    Dont know the screen but the matt side sounds right to me.
    the other side sounds very much like the back.
    check with supplier but 99.9% sure im right.
    (we have 1000's of installed screens all the right way round!)
    hope thats of help
