HELP! Sim2 HD300 to PC 1280x720p display problem
Discussion in 'Desktop & Laptop Computers Forum' started by Dts007, Apr 26, 2005.
  1. Dts007
    Dts007
    Dec 11, 2002
    131
    +5
    PC is set to 1280 x 720 and connected to Sim2 HD300 projector via VGA cable. However, the projector will only display 960 x 720 i.e. 4:3 mode rather than 1280 x 720 16:9 mode I want no matter what I do. The theater mode settings in Catalyst Control Center are grayed out, which have aspect settings, and the Powerstrip custom resolutions also seem to have no effect?
    Can anyone help me?
    Sim2 HD300 settings:
    Source: Graphics RGB
    Horiz. Freqency: 44.8 kHz
    Vert. Frequency: 60 Hz
    Resolution: 960x720 Mode:67
    Aspect: Pixel to Pixel
    Color Temp: Medium
    Software Version: 2.21.05 F (HPN)
    PC settings:
    Windows XP SP2
    ATI X800 XTPE graphics card
    Catalyst 5.3 set to 1280 x 720 (32bit)
    Powerstrip 3.59 Build 505 - Display Profiles/Advance Timing Options/Custom Resolutions … tried all 1280 x 720p options
    :lease:
  2. Kramer
    Kramer
    I suspect it's the PJ that needs adjusting. Probably a "through" or "wide" mode option in the menu somewhere.
    Try asking one of the Sim experts in the dedicated Sim forum here .
    :smoke:
  3. Dts007
    Dts007
    Dec 11, 2002
    131
    +5
    Thanks! I will try that...
  4. Dts007
    Dts007
    Dec 11, 2002
    131
    +5
    No luck! I tried that.......didnt work.
    If I set the pc to a 4:3 ratio eg. 1280x1024 then its fine except for the side bars of course! But 16:9 is a no go!
    Help!
  5. BarkerD
    BarkerD
    May 6, 2005
    25
    Orpington, Kent
    I had a similar problem recently which was resolved using Powerstrip. By creating a custom resolution of 1280x720p using powerstrip, the PC initially set the resolution to 960x720 just like you. When prompted whether to keep the resolution if I said "yes" it stayed at 960x720p, however, when I retried and said "no", the PC did not return to the original PC resolution but instead switched to 1280x720p - weird but it worked :clap:
