help setting up system
ellpeg1
:lease::lease::lease::lease::lease::lease::lease::lease:
i am sure you all have read a similar post many a time but please dont ignore it i need help
i am completely new to this, i need help on this set up and what cables i need many thanks go easy and explain all in idiot monosyballic form
the hardware involved is denon avr 1707 with denon dvd 2910 with kef eggs 2005.2 and sub woofer, tv is a toshiba 37wlt with 2 hdmi connections and sky+box
what cables do need?
how do i connect for best performance?
if i buy speaker cable do i need connectors?
does the speaker cables need terminated?
do i need an optical cable etc
intending to buy 25metres of 1.5mm vandamme blue
what else do i need?
the system will be used to play mostly dvds
is it worth upgrading to a sky hdd box?
will i get 5.1 sound from my sky+ box help
many thanks in advance
please help as missus is doing my head in after buying all this and still not connected
berkeley384
I am completely new to this, i need help on this set up and what cables i need many thanks go easy and explain all in idiot monosyballic form
denon avr 1707
denon dvd 2910
Kef Eggs & 2005.2 and sub woofer,
toshiba 37wlt
sky+box
what cables do need? How do i connect for best performance?
You need ...
1* Optical cable for Audio for Sky+
1*Scart Lead for Picture for Sky+
1*Optical Cable for Audio for DVD Player
1*HDMI lead for Picture for DVD Player
1*Shielded Single Phono (RCA) cable for the subwoofer
Sky
Connect Optical lead from optical out socket on sky box to optical in on the Denon amp, remember which optical in on the amp you have chosen as you will have to assign it to the relevent input option on the Amp - E.G. Optical 1 = TV - Go into sky audio settings on the sky box and set Optical Audio to Dolby Digital.
Connect Scart lead from back of Sky+ box to back of Toshiba TV
DVD
Connect 2nd optical lead from back of Denon DVD player to another Optical in on the Denon Amp, remember which optical in on the amp you have chosen as you will have to assign it to the relevent input option on the Amp - E.G. Optical 2 = DVD
Connect HDMI lead from Back of Denon DVD to one of the HDMI inputs on the Toshiba TV
Speakers & Sub
Connect up all speakers - be careful wiring up the rears, make sure you wire your rear speakers to the posts marked "Surround" and NOT "back"
Connect the Subwoofer to the amp using the Shielded RCA / Phono Cable - refer to the manual but there will be a socket marked "SUB OUT" or similar - Connect that to the input on the back of the Subwoofer
No - You can buy Banana plugs but I question whether they will really make any audible difference
No - You can just use the bare wire ends
Yes see above
Thats a matter of opionion - I have Sky+ HD and wouldnt want to be without it :smashin:
Yes - You will get propper Dolby Digital 5.1 from channels such as the movie channels where the program is broadcast with full 5.1 surround sound
For any channels that are being broadcast in Stereo (most channels) - set the amp to Pro Logic II (PLII) or DTS NEO 6
This takes a stereo signal and re creates the 5.1 effect with it.
ellpeg1
superb
wheres best bit to buy the cables and how much should i look spend
i have speaker cable thanks
thanks again
Danepack
and may i suggest to put a little sticker on each speaker cable strand...telling you if its fsw = front speaker white, fsr = front speaker red.
can be a nitemare if you have to hook another amp up and have all those wires looking at you:)
berkeley384
superb
thanks again
You dont need to go crazy with expensive cables here,
You could maybe just get them off Ebay or if you have a local Maplins or Richersounds .... but any decent AV / TV accessory place really
