help:Setting up new home cinema components
Discussion in 'AV Receivers & Amplifiers' started by witchdoctor, Jan 10, 2008.
  1. witchdoctor
    witchdoctor
    Hi there guys
    I have the following set-up:-
    ONKYO 7 Channel Home Theater A/V Receiver - TXSR605E (TX-SR605E)
    PS3
    SKY HD
    Pioneer PDP-506FDE with Media box
    Speakers - Duo Acoustics Duo-77
    :lease:
    New to the home cinema community - I have no idea how to connect all components other than the basics would really like to get the best out of my set up.…..please can someone briefly explain the connectivity and any glaring mistakes I’ve made in choosing these items. Do I need a dedicated DVD player or will the PS3 do??? Should I really be looking to replace the 50in Plasma with a LCD …..Would appreciate as much help as u can spare guys I’m a novice at all this …all the best for the New year and thank you in advance!!!
    :thumbsup:
  2. lowmans100
    lowmans100
    Dec 20, 2006
    1,480
    +461
    Use 3 x HDMI cables for video & audio
    Use RCA from PS3 for CD playback
    PS3 > 605 HDMI
    PS3 RCA out > 605 RCA In (CD) For playing CDs
    Sky HD > 605 HDMI
    Sky HD optical Out > 605 optical in for 5.1 audio from Sky HD
    605 > Pioneer Media Box HDMI
    The PS3 will work fine as a CD & DVD player
    If there is nothing wrong with the Plasma and your happy with why buy an LCD?
    I have a Pioneer 436XDE (2 years old) and I have no desire to get an LCD or newer Plasma (if it ain't broke don't fix it)
  3. googlebox99
    googlebox99
    May 5, 2006
    138
    +8
    Make sure on the PS3 Bluray you select the correct soundtrack - press Select and check the sound is Linear PCM (uncompressed sound). You may have to change the Bluray settings on the PS3 to make sure it is outputting Linear PCM.
    You will want to get your speakers in place and run Audessy sound config on the Onkyo to set up the levels etc (then fiddle with them yourself).
    I would suggest using "Multichannel" surround on the Onkyo for Bluray/games.
