mr starface
- Joined
- Mar 29, 2007
- Messages
- 2,917
- Reaction score
- 1,413
- Points
- 804
This is driving me nuts so any help is enormously appreciated! Story so far is:
I have recently purchased a 24gb My Book Duo but having a nightmare getting it formatted and recognised in windows 10.
Have tried on 2 different machines and googled for hours with no luck.
So I connect the drive up via USB after first installing WD Drive Utilities, windows recognises the drive and so does the WD utilities (there are 2x12GB drives) - so far so good.
You then tell WD utilities to configure the drives in whatever raid config you want. No matter what option I choose I get the error message "The configuration of the drive has failed"
Looking under disk management in windows the drives are showing as not initialised, but when I choose to initialise either as MBR or GPT I again get an error message saying "Incorrect Function".
Looking at the properties of the drive and under events I see the below message which indicates something is wrong but no idea what, have tried to download driver from WD website which didn't help.
So have my £400 drive sitting here and cant even get it recognised - whatever happened to plug and play!!
Device USBSTOR\Disk&Ven_WD&Prod_My_Book_Duo_25F6&Rev_1011\575542533239343931343536&0 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USBSTOR\Disk&Ven_WD&Prod_My_Book_25EE&Rev_4004\574343374B344A5945445A38&0
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000EC000000F120
Present: false
Status: 0xC0000719
Location Path:
Present: false
Status: 0xC0000719
