Help setting up my first dolby system
Discussion in 'AV Receivers & Amplifiers' started by bangaho, Jul 13, 2004.
  1. bangaho
    bangaho
    Ive currently got 8 speakers running in stereo, 4 on each channel powered on a vintage SA-606 amp.. i can get a yammaha DSPA5 ive got loads of good quality celestion speakers enough for a 5 channel setup.. but can i have all speakers playing from a stereo source? i dont want to have to just have the main 2 and the rest playing just echos n stuff is it possible to have them all playing all full bandwidth sound??? cuz i would like to have the surround but id also like to be able to have them all pumping out from a stereo source.. or something similar
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    You can use the various DSP modes on the amp to drive all your speakers (well 5 of them) from a stereo source. Some modes will od course be better than others, but Yamaha do have a good reputation for their DSP modes.
    The Dolby Digital and DTS surround modes that are available, are a nig step up from pro-logic but are only available on encoded discs (Pro-logic 2 is a vast improvement as well, but isn't featured on the A5).
    Have a look at this link, where you can see full spec of the A5, which is very well regarded.
    Yamaha archive
    The ideal solution would be to have a listen before you buy, as if you mainly listen to music on cd, a later amp with pro-logic 2 and DTS Neo 6 may be more suited to your needs.
    Hope this helps.
  3. Philly112
    Philly112
    Oct 17, 2003
    4,310
    Frodsham
    +1,657
    Just a word of caution here. Many amps do provide for the surround speakers to duplicate the front two in stereo eg my C2 processor has a 'Party' mode, which does just that.
    However, my old Yamaha AX1 didn't have this feature (or at least, if it did, I couldn't find it!), and as the A5 is similar vintage, I would doubly check it before I bought one
    Phil
