gscholefield
Established Member
Hi all, i recently brought this sub and have set it up as follows;
room size - 5m x 3.6m
settings on receiver,
front l/r speakers - small
sub crossover - 80 hz
sub level - 0
settings on sub,
low level gain - 12 o'clock
crossover - 120 hz
filter bypass - out
phase - 180 degrees
The sub is df and positioned 6 inches away from a wall, set up this way i get a spl meter reading of 74-75 db from the sub. The problem is that it sounds to boomy, watching Tron on blu-ray the room was shaking in parts as the bass seemed to over take the rest of the sound track. I had to reduced the gain to 9 o'clock but when i play music with the sub at this level it can't be heard. I thought it was important to set ALL speakers @ 75 db but with the sub gain at 9 o'clock i get a spl meter reading of 62 db. What am i doing wrong??
Many thanks, Gary
sub level - 0
settings on sub,
crossover - 120 hz
filter bypass - out
phase - 180 degrees
Many thanks, Gary
