Help setting up Home Cinema/Music System
Discussion in 'AV Receivers & Amplifiers' started by Ultima, Aug 17, 2005.
  1. Ultima
    Ultima
    Mar 3, 2005
    9,609
    +1,113
    Not sure if this is right place to post this but here goes.
    System comprises
    • Marantz SR5200
    • NAD C350 Integrated Stereo Amp
    • B&W LM1 Front Speakers
    • Bose Acoustimass 3 as rears
    • Cheapo Yamaha Subwoofer
    • Marantz CD52 Mk2 CD Player
    • Yamaha 550 DVD Player
    Not sure of the best way to setup this system, bearing in mind I want the best sounding music possible. The B&W LM1's are Bi-wireable if this helps. I know some people will say that the speakers will hold me back but I will change these in due course.
    Any recommendations on how to connect this system together? The technical terms sometimes go over my head so be gentle.
    Regards
  2. Ultima
    Ultima
    Mar 3, 2005
    9,609
    +1,113
    I was thinking on the lines of should I be connecting the NAD to the Marantz to the speakers or the Nad to the fronts and Marantz to the Rears and Sub?
    I was thinking maybe connect the NAD to the fronts and CD player to the NAD which I could use to play music. But where does the sub come into it?
    I could then connect the DVD Player and all speakers (Fronts Bi-Wireable) to the marantz for watching movies.
    Does this sound right?
    Any advice/recommendation would be most appreciated.
    Regards
  3. Ultima
    Ultima
    Mar 3, 2005
    9,609
    +1,113
    Anyone? Am I posting this in the right forum? Any help or suggestions would be most appreciated.
    Kind Regards
