sedalbis
Hey,
Please bear in mind that I am not techincal in this area AT ALL
Ok so I had normal Sky installed, cancelled my contract, and today went out and bought a Humax Foxsat HDR.
The man in John Lewis showed me the back of the box which had LNB1 IN and LNB2 IN. He said this was so that I could record 2 channels at the same time, and to do this I would need to buy a "two way satellite splitter".
So I went in to Maplins and bought the following:
- A two way satellite splitter which "splits the signal from one dish to two receivers"
- I also bought 2 satellite TV leads.
So I got home, and unplugged the Sky box. I then plugged the cable (coming from the dish outside) into the "IN" socket on the splitter I had just bought. Then from the two "OUT" sockets on the splitter, I attached the two new cables and plugged one into LNB1 IN and the other into LNB2 IN on the Foxsat box.
I then connected the Foxsat box to the TV and turned it on. It scanned for a satellite signal, and found it right away, then installed all the channels etc. At the end of setup, it gave me a summary. I noticed that next to antenna type it was showing up as "single cable". I then tried to record two channels at the same time and it was having none of it.
So obviously the splitter has not worked and it is just receiving one direct feed from the dish.
Please can anyone explain where I have gone wrong, and what I need to do to fix it. I apologise in advance if I have made an obvious mistake, as I said before I am not technical in this area at all.
Many thanks in advance
