gibbsy
This is the difference I was originally talking about. The Yamaha has a much better sound. You will have to live with the Denon for you to get use to it's sound. You are trying to model the sound from the Denon to that of the Yamaha and that's simply not going to happen with out compromising the Denons.This gave a much richer sound, but I feel that there is still something missing, maybe I'm just use to a fuller sound on the Yamaha.
I would give it some time and then re-run Audyssey once your grey matter is more accustomed to the Denons signature.
If you are listening in stereo then the Denon is still employing the bass management and the sub will be active. If you are happy with that then turn off +Main and let your sub do all the heavy lifting.I notice that even with the LFE + Main off the stereo mode with music button(remote) did infract include the sub any way, that's nice.
I would still try to get a higher crossover eventually as at the moment you are asking a lot of the Denon in the bass department and I dare say that is only for music as the actual LFE, the .1 channel, is usually pretty good and well balanced with Denon. There is a caveat in that statement as I'm running a higher tier Denon model but with a small and elderly sub.So, I changed the crossover back to 40 Hz
