I have hade the following setup :
Yamaha RX-A3030
Monitor Audio RX8
Monitor Audio RSFX
Monitor Audio RX Center
Velodyne spl-1200
Nvidia Shield Pro
Nintendo Switch
LG OLED65C8
Now I have replaced the Yamaha with a Denon AVR-X2700H because of bunch of problems that is solved with the new AVR.
I have done the following so far to setup Denon AVR :
The Subwoofer are calibrated and setup from before.
So am I on the right track? Is there something more I should setup?
I have notice that the night mode is hidden away even further away than on the Yamaha, with Denon its Setup > Audio > Audyssey > Dynamic Range, with the Yamaha it was just mini menu > Dynamic Volume. Is there a faster way on the Denon?
Yamaha RX-A3030
Monitor Audio RX8
Monitor Audio RSFX
Velodyne spl-1200
Nvidia Shield Pro
Nintendo Switch
LG OLED65C8
- Follow onscreen guide
- Audyssey MultEQ XT with measurements from 3 different places (around 50-70 cm from backwall and 60-70 from each other where 1 right Infront). I have another other off places to but no measurements was done for this (it’s about 2 m from center). The subwoofer was set on volume 30/100 and are not increased to 45.
- Change all speakers to Large
- Increase -4 db to -2 db on center to get clearer speech
- Change the Crossover from measured 110 Hz to 80 Hz
- Turn off Audyssey Dynamic EQ
- While playing movies Dolby Digital Plus or Direct is used.
- While playing music regular stereo is used. To get the subwoofer on the train the mode is set to LFE+Main.
