help setting up a panny pwd6 just bought it
Discussion in 'Plasma TVs' started by superbit, Dec 28, 2004.
  1. superbit
    superbit
    hi just bought this plasma screen today...... i previously owned a fujisu plasma and have it conneted via a svideo lead into my sony amp.
    i think i have bought the wrong module for it i have a scart module for it but there is nothing else to connect the screen up is it just a case of buying a svideo module for the screen perhaps they would exhange it for the scart module i have. really dont want to go down the route of using a scart because i recently set all my equipment up and think it would cause a big headache. anyone know what item nbr the svideo module is?
    thanks for looking
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    did you buy it from RS? if i doubt they will an S-video board....... aka TY-42TM6V (RCA's) / TY-42TM6BB (BNC's) (is compositeand S-video shared board)
  3. superbit
    superbit
    hi thanks for the reply it bought it from my brother in law, can i check that rca is also known as phono leads if so i think i need just the bnc module because its the picture only i need feeding to the plasma because the sound is dealt with by the amp.... any idea where is the cheapest to buy the bnc module?
  4. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,745
    Christchurch , New Zealand
    +736
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    RCA is the correct name for a phono lead yes BNC also known as Bayonet fixing
