Help setting up a BK400
JamesP1701
Hello all,
Have just received delivery of my new BK XXLS400 sub and wonder if I could get a bit of help integrating it with the rest of my system.
My amp is a denon 2311. The speakers are B&W: 685 fronts, HTM 63 centre and DS3 rears.
I have attached the sub via the SW output on the amp into the low level input on the sub. What frequency should I set the sub to? (Don't really understand how that works!) Presumably the gain knob I need to control is just the low level one?
fayeanddavid
Oh, and should I re run audyssey?
There is lot's of info on this in the 400 and Monolith thread however essentially you;
  • Turn frequency control to Max , or just past so it switches out
  • Turn Gain to 11/12 o clock position
  • Phase control at 0
  • Set all front speakers to small (LCR)
  • Run Audysey
  • Physically check Audysey linear measurements
  • and run SPL checks if you wish
  • then enjoy
mojogoes
Remembered (1961-2016)
So set phase to 0 frequency gain to 120hz filter to out/lfe and low level gain to the 11oclock position.......then go into your amp and make sure you have the sub turned to enabled and start with the xover at 80hz then a 100hz and then a 120hz and see which one sounds the best to you.......try all your speakers to small unless you have full range floorstander.:).....yes then run Oudyssey
Oops you beat me to it Dave:D
JamesP1701
Thanks for your help. It's a lovely sub and have set it up now. But...I can't tell any difference at all from my old Mordaunt short 903i!
nedmundo
Give it at least a few weeks to `loosen` up - then report back. I bet you`ll notice the difference then.
D
Deleted member 598831
I thought that too james, after coming from a 309 myself. I thought it was not as good at first,,,,,,,,,,,,,,,
Then I saw the light so to speak, no boom boom, but a nicer tighter cleaner bass
Steve
kiforrest
Watching this with interest. Considering the XXLS400 myself. Please keep us posted with your findings :smashin:
JamesP1701
mfife said:
Oh really? Have you tried playing a movie clip with lots of bass in it, really quite loud? Like -7db?
Sadly I can't get away with anywhere near the volume where I live.
I can hear a difference, perhaps not quite the scale I was expecting but there is certainly more precision in the bass.
JamesP1701
Meant to add, this is the spec of my 685s from b&w site:
Frequency range -6dB at 42Hz and 50kHz
Frequency response 49Hz - 22kHz ±3dB on reference axis
What should the correct crossover be? I can't really tell a difference between different settings. Probably my ears aren't sensitive enough!
hoppaz
If you have an av receiver try 80hz and 100hz and see which sounds best to your ears. If you have small surrounds you may wish to set their crossover to 120hz.
JamesP1701
Thank you.
Finally, what does the lpf of lfe option in my amp do? It's currently set to 120hz-is this correct? I'm slightly confused which frequency produces which sound. Is 150hz the bass sounds or is say 40 hz the bass sounds?
hoppaz
Thank you.
The lfe channel contains sound upto 120hz. Leave it as it is if it set this way for now.
Dont think of the sub being the only speaker to produce bass, all of the speakers will but the crossovers just help make them all work together. Most would define 150hz as bass and 40hz more so for your info.
