Petay
moving house has freed up some funds (the irony) meaning I can build out a 5.1 set up but I need some input on if my layout and equipment choice works in the room.
my existing HIFI equipment that will be the foundation
Roksan K3 Integrated Stereo Amp
Kef Q550
Rel T5i
I am planning to acquire the following for the 5.1 set up
Yamaha RXV6A
Kef Q250 C
Monitor Audio Radius 45 for surround sound
The diagram shows my proposed layout and its about all I can do with the room as putting the TV in the bay is a no no for the missus.
The TV will be wall mounted on the chimney breast and I am making up a mantle / shelf to go underneath to take the Q250C centre speaker.
The little MA radius will be on brackets above the sofa and will be angled down. The Q550 s will need to be non symmetrical to the fire place I think in order to calling with the sofa give its off centre to the fire place.
The sub placement is a bit iffy I think but I am limited, especially as I need to try and keep it away from the AV stack as I have a turntable on top of the rack. (this will be in the right alcove next to the fire as you look at the TV from the sofa.
any helpful comments greatly appreciated.
Kef Q550
Rel T5i
Yamaha RXV6A
Kef Q250 C
