Help - Setting Sound Level on Speakers
nheather
When setting up my 5.1 speakers I find that if I have the volume set reasonable I can't hear the centre and if I turn it up to hear the centre the effect sound from the fronts is deafening.
Doesn't matter whether I use auto setup or a SPL meter, the results are near identical.
Obviously I can manually reduce the sound level on the fronts but I'm confused why I need to do this.
If I have set each of the speakers to 75dB using the test tones why doesn't that work.
At the moment, I can't see the point of the auto setup or SPL meter if I end up doing it by ear.
Front and centre speakers are Canton CD50.
Any ideas?
Cheers,
Nigel
