The XP18 will work best with a 4:3 screen.
The projector has a 16:9 mode to give some of the benefits of anamorphic DVD so you won't lose out on the higher quality transfers.
The throw ratio for this projector is 1.9~2.47:1. For every 1ft of picture width you need between 1.9 and 2.47ft of throw distance. So, a 10ft wide image requires 19~24.7ft of throw.
Check your screen width then calculate the row required, or you can divide the throw by the each number (1.9, 2.47) to work out screen width.
Regards
Chris Frost
Regional Sales Manager-N.England & Scotland
Owl Video Systems Ltd
www.owl-video.co.uk
