Help! Scart switching & red tinge
Discussion in 'Cables & Switches' started by harvs, Jan 8, 2005.
  1. harvs
    harvs
    I've got a sony tv, humax PVR and ps2 and want to connect all three together using RGB scart.
    There's only one RGB scart on the tv, so I'll need a scart switch box to flip between the humax and ps2.
    When I connect just the humax to tv (using RGB output) everything is fine.
    However, when I route the signal via a scart switch box (I've tried 2 different types now) the picture develps a red tinge - which looks dreadfull
    Does anyone have any ideas of what's happening / how I can fix this? Both scart switches said there were RGB compatible, so I'm pretty confused. (The ps2 with RGB output works fine throught the switch boxes)
