Help Scanning Photo's!
Discussion in 'Photography Forums' started by WBC, Sep 17, 2003.
  1. WBC
    WBC
    Guys,
    I'm creating a wedding video and want to add a couple of old photos to the beginning of the movie.
    What resolution should I scan the pictures in at???? I assume that as they will be shown on a TV they will need to be scanned in slightly differently than normal????
    Please Help!
    Stace :D
  2. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    It's always best to go for the highest res available, then let your video-editing software interpolate / scale as appropriate.
    the only other option that will yield as good a result is to calculate the precise resulition that will yield the correct size for your video without scaling, but this is a bit excessive really!
