Help : Sanyo Z2 and Braveheart aspect ratio
Discussion in 'Projectors, Screens & Video Processors' started by edgler vess, Jul 21, 2004.
  1. edgler vess
    edgler vess
    Nov 23, 2002
    91
    I recently bought Braveheart and Moulin Rouge.
    The aspect ratio of the Dvd´s are :
    Braveheart : 2.35:1 ( approx) Anamorphic PAL
    Moulin Rouge : 2.35:1 Anamorphic PAL
    I am using :
    -Sanyo Z2 + Yamakawa dvd player + 720p DVI
    Question:
    Why,in Braveheart, am I getting small vertical bars in my 16:9 screen ?
    In Moulin Rouge everything is ok !!!
    Both films are 2.35:1 Anamorphic ...
    Is this because of 2.35:1 ( approx) ?
    The projector is 1.78:1 (16:9)
    The movie is 2.35:1
    The only way to display this without distortion is bars at top and bottom ... this is normal.
    But the problem is ... there are also small bars at left and right ... why ?
    In fact I don't see the same thing on any of my 2.35:1 Anamorphic dvd´s ... and I have more than one hundred ...
    Braveheart is the first situation of this black bars on all 4 sides of the picture.
    Can anyone with Sanyo Z2 or other 16:9 projector check Braveheart dvd specifically ??
    Help please ...
    Edgler
