Help : Samsung Service Menu Defaults?
Discussion in 'TVs' started by Marty McFly, Aug 30, 2003.
  1. Marty McFly
    Marty McFly
    Is there anybody here with a Samsung WS32 model TV that can quickly jot down the default values for me, my TV has now completely lost the plot.
    I am still getting the vertical banding I mentioned a month or so ago but now the colours are out of wack. Just want to check the values.
    Access the service menu via :
    o Go to stand by
    o Press DISPLAY MENU MUTE then POWER
    o I need as many values as you can jot down, just to check that it has been setup correctly but MAINLY need those inside G2-Adjust.
    Thanks in advance.
  2. jim.rae
    jim.rae
    Do you press the buttons one after another or all at once?
    I've tried my Samsung, but it's not responding and goes into the usual viewer's menu.
  3. Marty McFly
    Marty McFly
    You press the keys one after another.
    o Switch the TV on
    o Press Power on the remote
    o Press DISPLAY then MENU then MUTE then POWER again (remote)
    The menu should then appear in the top right of the screen. To get the menu off simply press Power again.
