Help - Samsung LE32M86/7 or LE37R87/8
Discussion in 'Samsung TVs Forum' started by olliegolf, Apr 25, 2007.
Tags:
  1. olliegolf
    olliegolf
    Jul 14, 2006
    60
    Simple question - no idea about the answer..(disregarding price)
    Viewing distance about 8 feet. Sky + and 360 main usage.
    The main reason i'd go for the 32" is for the 100hz screen.
    Obviously the 37" screen size is tempting but will the SD PQ be lacking in comparison to the 32"?
    Also i might be getting a V+ Box ... so that might help. Choices choices...
    This is tricky for me... currently using a 28" Sony CRT so i have no point of reference.
    Anyone have any thoughts? People with the Panny 32" 100hz care to share whether it makes a difference?
    thanks in advance !:hiya:
  2. mat060572
    mat060572
    Nov 29, 2006
    615
    Milton Keynes
    +19
    Beem going through the same thought processes recently but have gone for the 37" R88.
    Had a 32" Samsung before that and wished it was bigger within a week of ordering it.
    Hoping the 'Movie plus' feature on the Samsung helps put it on par with the 100hz models out there.
  3. olliegolf
    olliegolf
    Jul 14, 2006
    60
    Yeah the whole size thing is an issue.
    The 'boss' has limited me to 37" (as well as cost). I am just a bit worried that getting the 37" will be great but the PQ on SD sources (namely Sky+) will be poor.
    The PQ on the 32" with 100hz should in theory be better.
    Anyone know if the 'Movie Plus' feature works or is just a gimmick then?
    :lease:
  4. mat060572
    mat060572
    Nov 29, 2006
    615
    Milton Keynes
    +19
    Check out the R86/R87/R88 threads and also the M86/M87 threads as they also have this feature.
    I have Sky HD so I only really care that films and footy are best picture not too bothered about the wifes programmes - changing gardens and all that?????
