HELP!!! Samsung 42", which one??
Discussion in 'Samsung TVs Forum' started by Andy Christou, Mar 4, 2005.
  1. Andy Christou
    Andy Christou
    Hi guys
    New to the game, and need some help
    I am about to buy a Samsung 42" plasma
    Now is either the PS42D4SXX for £1899 from Currys
    or the PS42V4SX for around £1300 from the net
    i've seen previous posts on these models
    the problem is they look identical but i think
    i solved the mystery and found the difference
    The PS42V4SX hasnt got PC connection
    I badly need this
    Can somone please confirm that their PS42V4SX has or hasnt got PC con.
    Cheers guys
    Andy
  2. ukdan
    ukdan
    Feb 16, 2005
    1,136
    swindon
    +85
    do yourself a favour and get something else. I have a samsung and i dont think its very good. I just wish i found this forum before i made the mistake.
  3. Andy Christou
    Andy Christou
    Which model u got?
    Both of the ones i mentioned are 4th generation and a few good posts around.
    Plus cant really afford anything more than £1800 :(
    have u got PC connection?
  4. superpixel
    superpixel
    the samsung models are horrendous implementations of a surprisingly great plasma panel, unfortunately. have you seen it in action?
    forget the samsungs, forget the LGs.
    on your budget, I would only get either the Philips 42PF9946 (my recommendation) or a 'separates' package based around a Panasonic TH42PWD (which will give a very similar end result, IMHO). Choose what's best for you.
    A lot of people here may rubbish the Philips, but it is easily seen at every Currys/Dixons in the land so you can make your own mind up. I have just bought one, and everyone in the house agrees the picture is better than the Panasonic Viera, including my sister and brother-in-law who own said model.
  5. Andy Christou
    Andy Christou
    i knew i shouldn't have joint this forum
    i am well confused now
    i have to do more research,
    but please can someone confirm if the Samsung 42V4 has PC connection
  6. philip41
    philip41
    Feb 7, 2004
    237
    16
    Sussex
    join the club mate, do the research, ask the questions, but more importantly IMO get to demo as many screens as you can, and not just DVD demo's on the screens.
  7. Peabo
    Peabo
    The V4 has a DVI input but no VGA and you can't connect a PC to it, I used to own a PS42V4SX and neither my Mac nor PC would work on the DVI port. The Samsung TV isn't very good quality either, You can buy a Panasonic 42 inch PWD7 for well under £1800 which is really good and can connect to a PC.
  8. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I bought a samsung ps42v4sx and it had to go back. It is pants.
    Do a search of my posts for the gory details :eek:
  9. Andy Christou
    Andy Christou
    Gizzers,
    Thanks a lot
    I was going to order the V4 from the internet the other day
    After your comments, i thought give it another close look at currys (D4)
    completely useless, the LG next to it made it look really bad
    I was impressed with the LG (not sure of model , around 1500)
    but still wouldnt go for LG
    Thanks guys, back to the drawing board on the Panasonics,
    Philips and Hitachis
  10. tutin
    tutin
    Yes, forget the Samsung plasmas :suicide: . I also almost ordered the P42D4S and good lord, thank God I didn't. I loved the design of the TV and almost clicked the ORDER NOW button.. then I found this forum which gave me doubts about my purchase so I decided to delay with a day or 2 to checkout the local dealer and see how the TV actually does. And when I did see it I was shocked. IT'S BAD !
    I bought the Panasonic PW7 as everybody's recommendations as the best plasma panel at this point in time. I was expecting it this friday though it didnt arrive, i suppose monday, but I can already feel how great it is :) Can't wait :)
