Help - RX-V650 - Which Supplier?
Discussion in 'AV Receivers & Amplifiers' started by Mr Kennedy, Apr 10, 2005.
  1. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
    Ok all these are around the £250 mark. Now i've never used any of these, and i really would like either next day delivery or within 2-3 days.
    Digital Direct Uk
    Hughes Electrical
    Sound and Vison
    Prc Direct
    Also emailed Superfi to see if they price match as they are my normal supplier for AV stuff.
  2. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
    Ok after loads of hunting on here i could get the 750 for only £30 more from Germany so i did that instead.
  3. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    Ah good choice. I am sure you will not be disappointed. Well worth it for the extra £30!
  4. strontiumdog
    strontiumdog
    i was thinking of getting the rx650 but now ive read your post,i think ill go for the 750,which german site did you get the amp from?and also itsnt the power voltage and plugs different in germany?
  5. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
