Help! Runtime errors driving me crazy!
Discussion in 'Desktop & Laptop Computers Forum' started by buns, Aug 31, 2003.
  1. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    As per title, half the sites i go to are giving me errors and asking if i want to debug! I dont cant wont and never will want to so i click no..... but my head is getting very pickled by having to keep doing it! So does anyone know why this is suddenly happening and how i can stop it?
    thanks!
    Ad
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    Either you're beginning to visit some sites that are badly coded, or somewhere in your browser, java isn't being handled very well.
    If you're using internet explorer, there is an option to turn off the option to debug, if the site has errors, all that happens is a warning sign comes up in the bottom left of the browser window.
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    they arent bad sites...... places like yahoo has them, dvdforums, lycos..... nothing particularly odd!
    I'll go turn off the debug option. Thanks
    Ad
  4. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Tools->Internet Options->Advanced
    Browsing section
    Tick "Disable script debugging"
    Un-Tick "Display a notification about every script error"
    These are re-set to default if for example you add the Google Toolbar to IE
  5. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    actually the display a notification for every error wasnt selected, but i now have debugging selected so hopefully this will sort it out.
    Ad
  6. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Ok, something else new....
    Intenet explorer box opens with 'This page has an unspecified potential security flaw. Would you like to continue?'
    So why is it doing this now!?
    Ad
  7. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    If os is XP, have you installed SP1 ? I ask as i had java problems with some sites and SP1 resolved these issues.
