Help running the DVD!
Discussion in 'Xbox Forums' started by roy61uk, May 26, 2005.
  1. roy61uk
    roy61uk
    Have yesterday received 'Pro Evolution Soccer 4'and installed the DVD as per instructions.
    The autorun menue appears but when using the play option nothing happens, the Dvd drive runs for a time and then shuts down.
    Do you have any suggestions or is it a faulty disc?
    MY computer spec is as follows:
    Pentium 4 processor 3.00GHz, 800MHz fsb, 1MB cache.
    Windows XP.
    Memory 512MB Dual Channel.
    Video Card 256MB PCI-Express nVidia GeForce 6800.
    Hard Drive 160GB.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,128
    Canterbury, Kent
    +731
    Sounds like a faulty disc to me as your computer specs are fine for this game. have you posted this question in the PC gaming section? someone there might have an idea.
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,981
    167
    The Wheldon Road end!
    +8,122
    Personally i'd try the following :
    - Clean the disc by running under a tap and then drting with a lint free cloth stroking from the inside of the disc outwards.
    - If still doesn't work then try a full reinstall of the game.
    - If still no joy then try on a different PC if possible.
    - If all other games work fine using your PC's DVD drive then that would suggest that it's probably the disc that is at fault.
