Help, ruined DVD-R disks with my E50
Discussion in 'Blu-ray & DVD Players & Recorders' started by ABBITEA, Dec 23, 2003.
  1. ABBITEA
    ABBITEA
    Dear All,
    I set up my new Pana E50 last night using the excellent advice from Jem (Thanks).
    My set up is
    Sky+ tv out scart to E50 decoder scart
    E50 Tv out scart to RGB input on my TV
    My Tv is the Hitachi 42pd300 plasma
    I set the E50 to RGB input and out put.
    The problem
    I used the copy mode on the sky+ box to archive a programme on to DVD-r (Sony). I watched the programme start and the E50 start recoding but then went out, so I switched the TV off with the remote.
    Everything else (Sky + and E50) stayed on with all the same lights rotating or flashing.
    When I watch the recording the picture and sound are excellent until the point where I switched the Tv off, which is when the picture disapears but the sound still records onto the DVD.
    Does this mean that the TV has to be on for me to record to disk? Obviously this is not great.
    Any help appreciated before I put more money into Sony's pockets.
    Josh
  2. bobbles
    bobbles
    you must have set the E50 to record the wrong channel
    It should have been set to AV2 not AV1
    AV1 simply shows what is on the TV. So when it was turned off it recorded nowt
  3. ABBITEA
    ABBITEA
    It did record the sound and picture while the TV was on. But when the tv was turned off it only recorded the sound?
    :rolleyes: :confused:
  4. jem
    jem
    Sep 24, 2002
    527
    +7
    Can you confirm if you were recording from AV1 or AV2?
    The reason I'm asking is that recording sound and no picture can be a sympton of the E50 expecting an RGB input and not getting one.
    If you are sure that you recorded from AV2 you need to check a few things.
    1. Your Sky+ box is set to output RGB.
    2. You definitely have the TV out from the Sky+ box going to AV2 on the E50
    3. Your scart leads are fully wired
    4. Make sure all scart leads are fully pushed in.
  5. ABBITEA
    ABBITEA
    Okay just done some testing.
    Test
    Checked and confirmed that
    1. Sky+ tv out is connected to AV2 on the E 50
    2. AV1 on E 50 is connected to AV2 on the plasma
    3. Sky + is set to RGB
    4. E50 is set to RGB on both Av1 and Av2 + Normal connection
    Pressed record onto RAm disk.
    Recorded 10 seconds of Cbeebies (Arrgghhh)
    using the Sky+ remote pressed the TV button then the power button.
    Sky+ stays on, TV goes off, E50 continues to record
    Press power button on Sky+ remote (In TV mode) TV comes on.
    NB the screen is black but I can hear the programme sound. There is a icon that says AV2 on screen.
    Press the blue Sky button and the picture reappears.
    Stop recording and then play back.
    Results
    Programme picture and sound on the disk for the first 10 seconds.
    Picture then disappears but sound has recorded.
    :mad:
    Help. I can see my will to live loading its gun.
  6. ABBITEA
    ABBITEA
    Done it:clap:
    By trial and error decided not to use the sky+ remote to turn the tv off. By using the TV remote or the hard switch the black screen does not appear during recordings.
    Thanks for all your help.
    :laugh:
  7. jem
    jem
    Sep 24, 2002
    527
    +7
    You beat me to it. Apparently switching off the TV with the Sky remote puts the digibox into composite video and not RGB - therefore as suggested your E50 is not receiving an RGB picture, hence the sound but no picture.
    In fact any operation of your TV with the Sky remote will put your Sky output into composite video - beware!
  8. ABBITEA
    ABBITEA
    Thanks Jem.
    I have now started to archive the stuff on my SKY+ box that has been taking disk space for ages e.g the 3 concordes landing at Heathrow
    Have a great Christmas:smashin:
  9. jem
    jem
    Sep 24, 2002
    527
    +7
    Thanks.
