HELP!! Ricoh DVD R/W Drive problem
Discussion in 'Desktop & Laptop Computers Forum' started by jimyboyod, Dec 8, 2004.
  1. jimyboyod
    jimyboyod
    I have a Ricoh DVD MP5125A installed on my computer and can't figure out what the stupid thing is up to. I have got DVD RW disks and I cannot erase from them as it says that I cannot erase from this drive, but it is a RW so why the hell not? Also when i put in a DVD +R (which is the right type) it firstly tells me that it has 4.7G available but if try to burn anything (even a small file) onto it, it says that there isn't enough space and tells me to put in a DVD RW. What is going on? Ready for 'out of window' time
    :mad: :lease:
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,465
    Southampton
    +186
    What software are you using?
  3. jimyboyod
    jimyboyod
    Windows XP Operating System and Burn4Free
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Did this used to work and is now broken or has it never worked? Have you tried any other burning software?
  5. jimyboyod
    jimyboyod
    I have tried different software including the software that came with the drive when I bought it but it has never worked. I am just not sure if there is something stupid that i havent done.
