Help Required
Discussion in 'General Video Gaming Chat' started by Vodka Black, Sep 11, 2004.
  1. Vodka Black
    Vodka Black
    New user to Xbox live. Setup the connection using a Linksys WAG54G but using it as a wired connection.
    All was going well, connected and playing games then whilst playing XSN Hockey the connection dropped. Since then I can't get access to Xbox live and the troubleshooter is next to useless as everything checks out ok.
    Is there anywhere I can ping to see if my router/fw is blocking it?
    Any advice much appreciated.
    Cheers,
    Vodka
  2. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Do you have a firewall on the router?
