Help required - X-Box and Denon 2802
J
jag
I am trying to connect up my X-Box to a Denon 2802 amp. Is there anyone out there who has this, or a very similar, combo?
I have an optical cable running from the X-Box to the amp and have changed the settings in setup to point TV/DBS to Optical.
I cannot get Digital sound coming out though. Is there something I am missing? Should I be using something else other than TV/DBS?
Please help, I am in distress and Colin McCrae is calling.
J
jag
Yep. I've even tried the optical cable with the DVD and it works fine.
DodgeTheViper
Does the amp have a ' ext in ' option, as my 3802. I have my
X-BOX through the 3802, and it's wicked............. :D
Kev
J
jag
Kev
Not sure. I'll have a look. Can you let me know how you have it all setup?
Which connections are you using and what have you configured?
Cheers.
M
Machocomacho
Jag,
I have this setup the same way as you on my Denon 3802.
Set it to TV/VDP and make sure its in auto mode and
it should pick up as DD ( it does on mine ) If it does not
work what does it display as ?
The only other thing I can think of is to check your optical
lead 100% as my xbox one was a bit dodgy and replaced it.
J
jag
I was playing around with it last night and I finally got it to work. I think in the end it might have been the mode. I was sure that was set to Auto but it wasn't :eek:
Anyway, I now have DD5.1 and it sounds great on Sega GT 2002 :D
