Help required with an oldish sony all in one (SONY DAVS300)
Discussion in 'Home Cinema Buying & Building' started by jksurrey, Jun 15, 2009.
  1. jksurrey
    jksurrey
    Nov 10, 2006
    10
    hi all,
    I recently moved around my entertainment stuff and unplugged all the wires including speakers on my sony system.
    Plugging them back in now it seems that only about 3 of the speakers work :-(
    I have double checked they connectors are in the right way round. I have also swapped the non speakers round with the good ones and it seems the speakers are NOT at fault.
    Is it likely that that the player is damaged internally??? if so any ideas how to save it or just buy a new one??? It may be old but it looks great and id love to save it!!!
    thanks all!!!!
