dimmockg
Done a quick search and couldnt find what i was looking for.
Anyway, thought i would give the above a go and when i am on dashboard and go to media, then select Media Center all seems to be ok, but then when i select say Music (from the Media section on dashboard) it gives the option of Hard Drive or Computer, i select the Computer option & it advises:
To connect to a windows based pc, you must first download anad install media sharing software etc etc, please go to: (website)
I click yes to continue and i am then advised that no PC's can be found with media sharing software, then i test the connection and it gets as far as PC Selected and status is failed - now im stuck!!
I am running windows vista premium and i thought that media player/media centre enabled media sharing?
cheers
cheers
