Question Help required re: CCTV & router
Discussion in 'Smart Home, Climate Control & Security Forum' started by gwladok5, May 5, 2016.
Tags:
  1. gwladok5
    gwladok5
    Dec 2, 2004
    193
    +3
    Hi!
    Just about to have CCTV installed.
    With the NVR being connected cat 6 to my router, will I be able to view the camera feeds & control things on my PC as this is also connected to the same router? I'm running Windows 10.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Yes, as they will be on the same network
