HELP Required please
Discussion in 'Plasma TVs Forum' started by snappyq, Jun 28, 2004.
  1. snappyq
    snappyq
    Jun 28, 2004
    190
    hull
    +9
    want to bid on a 50" plasma on ebay,the model is sony KE-50XBR950 can only find this model on US sites and in the description is says it has a NSTC tuner,will this work in the UK?
    thanks in advance
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,400
    Southsea, UK
    +102
    Chances are if it has an ntsc tuner then it also has 110 voltage which will be incompatible in the UK.
