help required on camcorder selection.
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by amancalledchip, Jun 9, 2002.
  1. amancalledchip
    amancalledchip
    What i dont really need.
    -To be able to take stills( have a digital camera)
    -To convert any old formats i have ( use video in on Gforce3 to convert video to cd)Never had a camcorder before.
    -To spend a fortune
    I have for some time been looking at the Panasonic range The NvDS30B is one in particular, ( the 38b prior to that)
    The NVGX7B looks very nice but has many function i believe i would not really require for the £ 300 cost difference.Anybody have any recommendations please.Or a link to a site that does reviews of units.
    would be much appreciated
    Many thanks
    Steve
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,122
    Leicester
    +51
    Have you had a cam before,as I don't think you'll be disapointed with any digital cam?
    The same ultra compact design lower spec Panasonic GX7 ones look great to me.I've just bought the GX7 for it's ultra compact design and 1.2 MPixel stills and colour viewfinder.
    Check this site out for reviews,or any of it's magazine.
  3. stevie9856
    stevie9856
    Jun 9, 2002
    25
    Huddersfield
    Be carefull about the panasonic 30b i bought it , but it did not have analogue in ..... i swapped it in the end for a sony trv 240 which had analogue in/out and pass-through ideal for my old vhs tapes.
  4. stevie9856
    stevie9856
    Jun 9, 2002
    25
    Huddersfield
