Help required - IR reciever
Discussion in 'Desktop & Laptop Computers Forum' started by adesonic, Jan 21, 2004.
  1. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    Can girder see a USB IR reciever attached to my HCPC?. I have installed girder but it cannot find an infrared port even though my PC has a USB reciever (which does work!), Does the reciever have to be on an "old fashioned" serial port?
    Ta
  2. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    I have the same problem. I have a DigiTV card with its own IR Receiver but after contacting nebula-electronics they said they do not support girder with their IR receiver :(
    Anim
  3. GForce
    GForce
    adesonic - Ive been looking into girder the past few days - Just a quick check - It doesnt support IRDa - the type used for mobile phones and builtin on laptop etc. They operate on a defferent frequency range.
    Just somthing worth mentioning ...
    Regards
    Gareth
