Help required connecting DVD and Sky+ to TV
Discussion in 'Sky Digital TV Forum' started by Gibbo5, Aug 30, 2004.
  1. Gibbo5
    Gibbo5
    I hope somebody may be able to help me with this.
    I am trying to connect a Toshiba DVD player with coaxial and optical outputs and a Sky+ box with only a optical output to a Philips Dolby Digital TV with only one coaxial input.
    Is there a way of doing this so that I can have Dolby Digital 5.1 from both my DVD player and Sky+ box or will I have to sacrifice the sound quality from one of them.
    I have browsed the web for converters and splitters but could only find a converter for changing one optical input to a coaxial output, and a optical splitter that splits a optical input to two optical outputs.
    Any advise would be appreciated.
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    You need one of these (or similar)
    Click here
    HTH
  3. Gibbo5
    Gibbo5
    Thanks AV Junky, with it and an optical to coaxial adaptor it should work.
