Help - Require 2 SVHS Outputs
Discussion in 'Plasma TVs' started by Drogo, Sep 18, 2005.
  1. Drogo
    Drogo
    Dec 13, 2003
    287
    English Riviera
    :lease:
    Morning guys,
    Can anybody please advise, as I have a Panasonic Plasma, and have just purchased the Epson Projector, now everything is running on SVHS and is plugged into my Joytech unit, however the Joytechy AV unit only has one SVHS output, and I need two, one for the Plasma, and one for the Projector...
    I don't want to buy a AV amp with two/three outputs as I can't fit anything else in my fireplace (AV stuff) is all built in ...
    Does anybody now of anything that will allow me to take the output from the Joytech AV unit and plug it into something that will give me 2 or more SVHS outputs so that I can then connect to both devices..
    Hope the above makes sense - I do tend to waffle..
    Thanks in advance guys....
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Your cheapest/most likely option is some kind of scart multiplier, try keene electronics or Lektropacks. Scart apparatus is not usually fussy about what is carried on the plugs. If it's fully wired, it will do the job.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
  4. Drogo
    Drogo
    Dec 13, 2003
    287
    English Riviera
    Thanks guys will look into both these options, although I want to stay clear of scart ..
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It'll be a cost based decision I'd guess. Kramer stuff is excellent, but not budget orientated.
