HELP - Remote question - Home Theatre newbie
Discussion in 'Hi-Fi Stereo Systems & Separates' started by santosh_lg, Jun 16, 2009.
  1. santosh_lg
    santosh_lg
    Jun 3, 2009
    3
    i posted this before but no response. Just wanted to take a second chance with your help.
    Is it always possible that all the remote functions can also be controlled by the keys on the DVD player or are things more advance now .. that a remote is completely necessary!???
    I bought a LG HT 752 hometheater dvd player without a remote.
    It seems to give out only a 2.1 sound because i can hear only two speakers.
    I am wondering if I can use the key pad to make it emit a 5.1 surround sound.
    Any help?
    Thanks in advance.
    Santosh
  2. s_d_grif
    s_d_grif
    Oct 13, 2008
    254
    28
    Kenilworth
    +81
    Hi Santosh,
    I'd suggest going to the LG support site and downloading the manual to see what options can be changed with/without the remote but your likely to have to change the speaker settings to let it know how you've set the speakers up (and normally Setup is remote based).
    You probably didn't get a reply because it only took me about two seconds with google to find the manual...
    Good luck, Stu
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,922
    Another option is to get an all-in-one remote such as a Logitech Harmony.
    Their database should include all the settings for you system :smashin:
