HELP rel strata
gray3393
Hiya
Has anybody have an idea how much they are worth.
Is there alot of diference between the mk1 or mk2 in the sound.
And are they any good for movies. Any opinions please.
Gray
Member 96948
For the performance on offer, no more than £300 absolute tops.
Don't know.
Not compared to what can be had for a little more.
How much are you willing to spend, what size is your room and are there any other considerations?
Russell
gray3393
Hi Russ,
I picked on the rel strata as they seem to be going for a round the £80 to £120 mark, so thats a clue of how much i realy want spend.
My room is 7m x 4m. I also listen to music as well
Gray
gray3393
Cheers for that Russ,
Forgot to mention the speakers i have are def tech pro80's.
Would a rel strata be ok with these.
Gray
Ian J
They should do. I had a REL Storm when I had the Pro 80's and they went together very well.
gray3393
Thanks Ian,
The reason i've asked this is becuse the sub that came with this the crossover was 40hz to 150hz & the rel goes to max 120hz.
Would this be a problem with 30hz missing?
Gray
Ian J
I had mine crossed over at 80Hz but that was using the amp's crossover with the sub's crossover switched as high as possible so that the two crossovers didn't overlap
gray3393
Cheers Ian,
I will do that if i get a rel.
Also is the strata a good sub i Know you said you had the storm but thats a bit too big for me. As i have a chance of a strata mk1 for £100 is that good or bad.
Sorry for being pain
Gray
KUBBY
Have you tried contacting REL? HERE
A new thread might have been more suitable for this question.
Good luck,
K.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
