AudioNut83
Hi there
I was wondering if the rega io would power my 8ohm speakers with power handling rated between 50-150 watts?
I know the rega io’s power is only 30watts per channel so I’m a little concerned that it’s a bit to weak for my bookshelf mission speakers. I currently use a marantz amp but I’m not happy with the overall quality of the unit, and it’s on it’s way out so I need a replacement, preferably one that’s an upgrade over the marantz.
Also do any owners whether the io sounds any better than a marantz pm6004? If not what about the brio? I know better is largely subjective but still, I’d like to hear people’s views on these rega amps.
Many thanks
Many thanks
