Help really really needed
Discussion in 'AV Receivers & Amplifiers' started by [RwS]Skirge, Jan 10, 2004.
  1. [RwS]Skirge
    [RwS]Skirge
    Hi guys first time on here i felt to ashamed to visit here when i only has one of those Bush DD all in one setups...
    But today i bought a Sherwood RD-8108 AV Receiver but alas it came without user manual and my head is batterd, i have searched the net with no luck even the Sherwood website is crap..
    So if any of you have or know where i can get a copy of a user manual for a Sherwood RD-8108 i will be eternely greatful..
    Many thanx.......Kris
  2. Dom36
    Dom36
    Aug 26, 2003
    285
    Good ol' UK
    +6
    Hmmm why did you buy an amp without a manual?
    I've had a look on the site and a quick search of the internet with no luck :(
    Only thing I can think of is ask the company you got it from to get hold of one for you, or contact sherwood directly...seem to only contactable in America though...:-\
  3. [RwS]Skirge
    [RwS]Skirge
    Thanx m8
    I bought it without the manual coz it was only £99 i thought that was cheap for what it is, and i thought i would be able to work it all out...
    I have asked where i got it from if they can locate me a manual but i have had no responce so far....
    A google search turned up the fromt page of the manual in PDF format but tyat was all, even the Sherwood site is bad
    not even a contact e-mail addy...
    oh well i shall keep on searching
  4. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
  5. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
    If you are still having a problem you maight consider ordering a manual directly from Sherwood in California. You can call Eugene Chavez at (562) 741-0960 (Ext. 115) and I'm sure he can help. My experience is that you can order over the phone with a credit card. The major difference between the units sold in the US and the UK is that RDS (Radio Data System) functionality is not present on US units becasuse most radio stations don't use it. So that section of the manual will not be included, and there may be other small differences (such as power supply related discussion) that will be different too. But in terms of overall understanding of how to operate the receiver the US version of the manual will do the trick.
  6. [RwS]Skirge
    [RwS]Skirge
    Thanx guys
    We did call Sherwood they gave me an e-mail addy to ask for a manual
    i did and have had no reply and this has been over 1 week now...
    I think i am doomed not to ever get a manual.
  7. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
  8. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
    I just found the RD-8108 manual posted on the parent company web site. Go to: http://www.etronics.co.kr/english/index.html find the "download" tab on the banner toward the top right of the page, and when you see the download index go to page 3. Hope this solves your problem.
  9. [RwS]Skirge
    [RwS]Skirge
    THANKYOU THANKYOU THANKYOU THANKYOU THANKYOU
    OH M8 U R A STAR WELLDONE !!!!!
    Great M8 exactly what i needed problem solved :D
