For the tweeter, I'd say red wire to left hand side connection (left hand terminal seems to have some red on it), and black to the other terminal.
I can't see if there is another wire for the left hand woofer, but judging by the single cap on the crossover, and if the woofers are 4 ohm, the yellow wire by the r/h woofer will go to the positive, the yellow wire with terminals at both ends looks like a link from the neg of the r/h woofer to the pos of the left hand woofer, and the black wire by the r/h woofer looks like it should go to the neg on the left hand woofer, so needs to be moved across.
I'm guessing the two woofers were wired in series directly to the input, and the tweeter has a single capacitor in series with it.
Are the pics showing everything or is that it?
